BubDelicious's avatar
BubDelicious
Who knows what this is? (Hint - Maxxis)
I felt it was my duty to report this to the forum. Had a complete tire failure on the way to Cedar Point this weekend. I have seen a lot of threads about ST tires and Maxxis so I thought I should post up my blow out. Background on these tires, DOT code 5009, load range C(original load range was B), all 4 tires PSI checked before leaving were 53-54PSI. I was on OH-2 running 55mph(had been running 70mph on the interstate before), luckily I had friends behind me to let me know I had a flat(I did not feel it, hear it, or see anything). The other tire on the same side started to wear and scuff pretty good(holding all the weight) after this tire blew, but finished the trip with no issues. The spare that I used was the original spare, DOT code from 2003, load range B, Marathon made in New Zealand(never used, still had dimples). Iam still a fan of Maxxis(run them on my quad), but not ST tires. I will be taking what's left of this tire to Discount Tire today to see if they can replace it under warranty. Lastly, I would like to give a shout out to the Ohio state patrol for pulling in behind us with flashers on and actually helping to change out the flat(hands on grabbing tools and caring the tire to the truck).
  • I'm glad no other damage was done from the blowout. I doubt you will have much luck getting it warrantied since the tire is almost 5 years old unless they were recently installed, in which case, I would be talking to Discount about why they installed such old tires.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
