Grit_dog
Sep 12, 2021Trailblazer
jffnkrn wrote:
yeah 6 speed tranny with manual for hill climbing and descending. In the other trucks, I would run in 5th to keep it from trying to go into overdrive/6
5th is OD is well, FYI.
Whether you’re pulling in an OD, direct or an under drive gear is mostly a function of can the engine and gears pull it. Gone are the days of OD gears not being able to handle stock power. That hasn’t been an issue since the 90s ish.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
