kamperdog's avatar
kamperdog
Why do I have sway with a WD hitch and sway kit?
I don't understand. I'm starting to think I don't have my tire pressures right (tandem setup) My base tongue weight is 219 and I know to load a trailer with more weight toward the fron (the old 60/40 thing). It still swings back and forth too much and heaven help me when a semi passes by - a full 10 on the sphincter scale. It could also be my tow vehicle, a 2004 Jeep Grand Cherokee with 4.0L pulling a trailer with a 3500lb dry weight. May be just too much trailer for the vehicle. But I still get what I think is too much sway with it even though I have a WD hitch and the 4-point sway control setup.
So I'm looking at the tire pressures on my trailer. How would you set your pressures on a tandem axle setup?
  • Well I'm loading everything I can toward the front of the trailer. What else can I do to increase the tongue weight? Add a battery or two?
  • Yes. It's all about balance, and your's is off. And once you get the correct amount of tongue weight. You will need to readjust the WDH. Remember. A weight distributing hitch. Has to have weight to distribute. No weight, and no weight is moved.
  • You need about 420 lbs of tongue weight for a 3500 lb trailer.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
