MitchF150
Jul 03, 2022Nomad
Why would any of our opinions (or facts) make any difference? :)
It sounds like you are satisfied with the way your rig tows right now, so why mess with it?
I wouldn't change anything.. If you have the 2.5" hitch receiver and not using the 2" spacer piece and your drop and ball are all within spec of the tongue/trailer weights, and the sag is not any major concern, I'd just go with it until it isn't.
The Ford's 'built in sway control' only kicks in when you are in a severe 'sway' situation. If it kicks in, you are not in a good place and maybe you need to adjust something.
I use a WD setup, but no mechanical 'sway' control with my setup.. I've had my share of emergency stops and wind and other situations that are not your ideal towing experience, but have never had Fords 'sway control' ever kick in.
In the end, do whatever lets you sleep at night.. If all you do is think you need a fancy sway hitch, get one... Nothing wrong with that.
I sleep just fine with my setup. Sounds like you do too.
Good luck! Mitch
Good luck! Mitch
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
