dodge_guy
Jul 04, 2022Explorer II
With an F350 and an Airstream you don’t need a WD hitch, the hitch itself is rated for the tongue weight of the trailer. It also has he diesel up front that helps offset any weight put on the hitch.
And some need the WD hitch. Such as my V-10 Excursion with a TT with a 1200 lb tongue weight. Even if the hitch was rated for the 1200 lb tongue weight without a WD hitch needed, I would have still run one.
Most of the manuf will tell you if and when one is needed.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
