Grit_dog
Jul 04, 2022Trailblazer
theoldwizard1 wrote:Microlite Mike wrote:
A Weight Distribution Hitch may be required in order to meet the load ratings of for the receiver attached to the tow vehicle's frame.
Even if you have NOT exceeded the receiver weight rating you gave significantly changed the amount of weight on the front. Your steering will be "vague" and you will have less vehicle braking. A weight distribution hitch prevents both.
You forgot the rest of the story…..”if The trailer removes enough steering axle weight to be of significance.”
Simply not an issue with a lot of setups. I got over 1500lbs tongue weight sitting on the back of the ole brodozer. I’m sure the front end still scales more than a comparable gasser even with trailer attached.
Why is that dangerous?
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
