Lantley
Jan 27, 2016Nomad
goducks10 wrote:
I look at the UVW, GVWR and CCC. I know what I can tow, I know what I carry and I know how much in reserve I want. If you know all that then it doesn't really matter if you're maxed out after loading or still have 2-3000lbs left before reaching the trailers GVWR.
My 5er has 4315lbs of CCC. I only load 1500lbs max in it. It also has a GVWR of 11,400lbs. If I used the GVWR I couldn't tow it because my truck doesn't have the payload capacity since the pin would be around 2200lbs. I only have 2176lbs for payload in the truck. However it only weighs 9000lbs when loaded and has an 1800lb pin. So for me if I used the 5ers GVWR I couldn't tow it.
The reason people say to use the GVWR is to take the guess work out for newbies.
I agree they use GVW to eliminate guess work and to present worse case scenario.
If you don't load to max you will not be at worst case scenario.
If you are too green/new to understand than worst case is used as a guide line
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
