poppin_fresh's avatar
poppin_fresh
Why GM? Why?!!!
I went to move my brake controller from my 2012 Chevrolet Traverse to my new Silverado for our first trip tomorrow. I figured it would be a simple matter of unplug, mount and replug.
Nope! The plug on the harness is completely different! Had to cut the wires and re-splice into the harness that came with the truck.
Granted it wasn't hard to do, but I was only mentally prepared for half that much work. :)
  • Because they can and their customers will continue to purchase new models...
    But...over on the commercial/industrial side...they keep their revisions
    backwardly compatible as much as possible...because those customers typically
    will NOT purchase again...or delay purchase until there is a significant
    benefit
    Mainly because commercial/industrial keep their equipment for decades or
    longer. So spare parts and replacement part interchangeability a critical
    decision point
    The philosophy of Corporate parts bin and compatibility is getting lost
    with the new designers & their management.
    They even used to include the pig-tail harness. but no more
    The whole vehicle harness still (that I know of) has the tow/trailer
    wires 'n there' and am expecting the OEMs to remove that as a cost
    savings thing all too soon...as the percentage towing is very, very
    small...and...the OEMs can then make money from those who then purchase
    the tow harness(s)
    Can also see the 7 pin connector change with more connections. That
    will be when there is a complimentary computer/sensors/etc on the
    trailer. Mainly a strain gauge for the computer to know if over loaded
    or not...
  • mleekamp wrote:
    BurbMan wrote:
    They have done worse....in 2002, they changed the pin layout within the connector. So, a 2001 pigtail will plug right in because teh connector is the same shape, but nothing will work because the connections have been rearranged.
    I had this happen...our 01 Chevy was wrecked, got a new 02, and plugged right in. Problem was, NO TRAILER BRAKES!!!! Had to pay $60 at a dealer for the new harness. I still curse that.
    If it was the same plug why couldn't they or you just change the pin locations.
  • There was one change made that if you used the prior model harness, if you turned the headlights on it applied the brakes. They had reversed 2 pins for whatever reason. There is a bunch of Latin about all this, but I'd be preaching to the choir.
  • ScottG wrote:
    While we're at it, why do Ford and Dodge think I want the headlights to come on just because I open the door? How many customers wanted that?
    Sell that 03 and get a new Ram Scott... you can turn those headlights off in the settings. :B
    My "old 03 doesn't do it but I noticed the new ones do. So that's it, I'm never selling my 03 ;)
    I remember that debacle!!
    I think they eventually changed the pigtail connector color to easily distinguish which pigtail was meant for which year truck.
    Same thing going from our 02 Avalanche to our 00 Yukon XL 2500. Everything worked except the trailer brake signal. $12 on Amazon for a new harness from Tekonsha, but it was a pain to use the manual slider for brakes on every stop on that first trip.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
