- moebedickExplorerF250 space cab toting a Northstar Freedom that overhangs my windshield about 18". Transponder wouldn't work anywhere in the cab on trip back to Massachusetts from Utah. Even tried holding it out the drivers side window. Replaced it with a front bumper mounted transponder and problem solved. Beware! People will steal them off the truck,so you must use locking screws ( special tool required to remove and install).
- slacker_crusterExplorerThanks for all the feedback!
I'm using the PA TP going from Pitts to NY. - slacker_crusterExplorer
DrewE wrote:
I would imagine a fair few of both sorts have done that. I haven't generally heard of problems with it there for class C's, and would not expect that truck campers would have problems either. If it doesn't read, it may do better on the dashboard at the base of the windshield, or in the worst case you can get a transponder that mounts to the front license plate mount. Alternately, particularly if you have a front window on the truck camper, you could put it up there rather than in the truck cab proper.
If the transponder can't be read, they'll generally read (photograph) the license plate of the vehicle and find the account that way. That can also happen when the battery in the transponder wears out.
Thanks! Didn't know it had a battery. Thought it was just a chip. - WNYBobExplorerMine didn't work behind the mirror! (got charged max rate on NY Thruway) I just set it on the dash at the windshield, worked fine there.
Watch the signs to make sure it registered, if not make sure you know the date, time, exit number and lane, then call ez-pass for the state your in. - OldRadiosExplorerOurs didn't work half the time mounted up by the mirror. The cabover did block the signal at some toll booths. Moved it to the bottom center of the windshield and no more problems.
- suprzExplorerI have a class C and I have a plate mounted unit, works fine.
- Jack_SprattExplorerMine is next to the mirror and works fine with our
AF 811 on - 2oldmanExplorer II
- DrewEExplorer III would imagine a fair few of both sorts have done that. I haven't generally heard of problems with it there for class C's, and would not expect that truck campers would have problems either. If it doesn't read, it may do better on the dashboard at the base of the windshield, or in the worst case you can get a transponder that mounts to the front license plate mount. Alternately, particularly if you have a front window on the truck camper, you could put it up there rather than in the truck cab proper.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
