Only_True_Mosno's avatar
Nov 16, 2017
Will B & W Patriot Glider fit on Pullrite Rails?
I am selling my Pullrite Superglide and am purchasing the B & W Patriot Glider rail mounted hitch. Does anyone know if the B & W will simply mount to my rails already installed, or will I need new hardware and rails? B & W website states fits “universal standard rails”, but I don’t know if Pullrite is standard rails? I am hopeful all I need to do is pull the Pullrite out and drop the B & W in? Thanks!
  • Only True Mosnowman wrote:
    Heard back from B&W..like above poster mentioned..it’s a no.
    I am switching because I have had a lot of trouble hooking up with my Pullrite. You have to always be straight on and level to avoid fighting it. I prefer a hitch that I can use hooking at an angle if needed. Just not my cup of tea....
    As great as the Pullrite is, that was one of the things I didn't like about it when I had my last truck. I often had to unhook and hook with the head attached to the 5er. I also purchased the B&W this time around.
    Dan
  • Heard back from B&W..like above poster mentioned..it’s a no.
  • Depends if the Pullrite is a ISR (industry standard rails) model. Wonder why you're getting rid of the Pullrite
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
