bid_time
Jun 03, 2018Nomad III
It's not the compressive strength you need to worry about, it's the flexural strength and bearing strength below the slab. Then add in W/C ratio, expansive soils, improper curing, segregation, air content, inadequate compaction, etc. Long and short of it, there is no one here that knows the answer but it sounds like you did everything right; If the installer held up his end you should be ok.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
