joshuajim
Jun 06, 2018Explorer II
westend wrote:
Guys, it's not that simple, at least in the building engineering world. There are forces of compression, tension, restraint, strength, loads (both live and dead), and others I've lost in my memory.
The OP states a compaction of up to 40" of fill and a further layer of gravels, also compacted. He is far above any typical placement of slabs for the use involved. Letting these base layers sit and compact/firm up over a span of time also add to the integrity of his installation. About the only thing that would aid in the strength of the slab is installation of steel rod. He has used wire, which is adequate for this use.
I completely agree with your first paragraph, but I have issue with your second. Letting material "set" over time will result in the material settling, but never compacting. If that was the case, then every piece of native soil would be at optimum compaction due to millions or billions of years of "setting". No, native soils is at 65 to 80% of optimum no matter how long it sets.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
