luberhill's avatar
luberhill
Will my garage floor hold a motorhome ?help
Ok my pole barn has a 4” slab, 4000 psi concrete with fiber and wire mesh,,,it compacted bankrun gravel and crusher under it
How much does a 29 ft class a or c weigh ??
And is this floor sufficient ?
  • 4" of 4000 psi concrete on a tight base will hold anything you want to park on it.
  • I wouldn't think there is any problem, Class A typical is max 22,000 and a C is usually max 15,000. Then divide by 4 to spread out the weight even more, I doubt it is an issue. Prob some engineer will chime in on this.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
