MikeSherman's avatar
MikeSherman
Will This Work?
After years of towing small trailers with a strong TV (weight was never a factor) and owning a couple of Class A MHs we have decided to buy a 5th Wheel and P/U truck, but I'm having trouble figuring out all the weight, tow ratios, etc. for the combination I am looking at. Perhaps someone can give me some advice on the following units I am considering and let me know if I am within a reasonable limit.
THE TRUCK: 2001 Ford F-250 4x4 short bed 7.3 diesel w/tow package & slider hitch.
THE 5th WHEEL: 2004 Forest River Cardinal 33'
UVW - 10,500#
GVWR - 14,110#
Considering we will be full-timing, I assume we will pack in what, 2000#? I'm thinking the trailer is too heavy for the truck, but I may be missing something in the equation. Any input provided will be appreciated.
  • Go one size bigger on the truck (F-350) and enjoy.
    Used this combo ( 2004 F-350/==/2003 33CKTS from 10/2003 till 10/2013
    C.B.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well I will call it borderline to be nice. The following is not a recommendation just what is currently working well for us.
    Our package is 2001 Ram 2500 5.9 CTD with a 3.55 gear, and a small chip 50hp and 140#.
    The 5er Dry 9,820# with a 12,360# GVWR currently loaded to about 11,000+/-
    No I am not currently overpowered, nor am I under powered. I can keep up with traffic in both the Coast Range and the Cascades.
    DW and I plan on taking this rig into retirement and Full timing.
  • When estimating TV capabilities for a 5vr, I'd add 2500# and 25% pin weight.
    That'll give enough cushion to tow easy.
    For your consideration, 12500# and 3125 pin weight.
    A 3500 is in your future. But look closely at the TV payload if buying older.
  • You really want a 3500SRW minimum. Dually would be a far better choice.
  • Your thoughts are correct. Never helps to be on the borderline of trucks limits.
    Jim
    (you can never have too much truck)
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
