- buta4ExplorerLook at the Hekla Fire Box!
- rexmitchellExplorerPark your car upwind side of the fire.
- IAMICHABODExplorer IIWhen we are at the beach This Shelter is what we use around the firepit to block the wind.
- Deb_and_Ed_MExplorer IILook for "beach shelters" - portable nylon wind and sun protection. Just don't get it too close to the fire ;-)
- FishermanExplorerHow about plastic 4x8 privacy lattice, many colors and light weight. Cut the sheet in half and hold it up with a couple of stakes. https://www.homedepot.com/b/Lumber-Composites-Lattice-Vinyl-Lattice/Brown/N-5yc1vZbvh1Z1z0vl9p?storeSelection=1287,1233,1234,1268,1228
- lc0338ExplorerI have 4x8 sheets of plywood that I lean up against the backs of the chairs or bench. I can move it around depending on the wind direction. You can drill holes in the top and bottom along the ends and tie multiple panels together and when no longer needed they can be stored out of the way. The heat really reflects off them and helps warm your backside :)
- _1FlyboyExplorer II.... Also needs to be not too big as it’s only needed for 2 people around a campfire....
- LwiddisExplorer IICampfire in breezy conditions?
- Grit_dogNavigator IIIPlenty of little soccer mom type 3 sided shelters that block the wind and rain should fit the bill.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Nov 26, 2025
