cdlaine's avatar
cdlaine
Wind Tunnel testing ????
Does anybody know if any in the RV industry are
using wind tunnel test results in manufacturing
build specifications ?
I was watching MotorWeek and they showed /
demonstrated the effect of rear end drag
created by a what was a "boxed" rear end.
(the "smoke" broke up immediately after
passing the rear of the vehicle ). Apparently,
the smoother the transition post vehicle the
less drag...modifications included "smoothing"
under the vehicle. I don't understand all the
engineering/aerodynamics but does seem plausible
to apply testing to the RV industry. My review
of the European RV market seems to indicate
they are paying attention.
So, why is this important ? Average cost of gal.
of gas between $3.20 - $3.60 (diesel more)... and,
the experts "predicting" only going higher. Might be
time to give a little more then lip service to
RV aerodynamics.
What say the congregation ?
Interestingly, the wind tunnel effects have been applied
to just about any type watercraft, or aircraft...just haven't
seen the RV in the discussion.
Charles
  • One look at the back of most RV's answers that question don't you think?
  • Thats_Ok wrote:
    Mmmm...
    I do think air dumping off the sides, top and bottom of a large vehicle does actually help push the box at highway speeds due to the air void.
    Kind of like the pickup tailgate down myth.
    Actually the high pressure up front, the turbid air alongside and under the vehicle, and the low pressure at the back all combine to generate considerable aerodynamic drag.
    Leaving a pickup tailgate down actually hurts mpg due to the swirling affect and creation of a low pressure zone
    Studies have been going on since the 1970's but more interest has been shown lately.......wind tunnel studies of semi trucks/trailers ie: Cab side/top extensions, side fairings and rear wings.
    The rear area has been toughest to improve upon due to the need for large flat doors
    Aerodynamics Research
    Tractor Trailer Aerodynamics
    V-shaped trailers has been one attempt at reducing drag.
    Problem is like an octagon home....kinda neat looking but lots of wasted space
  • If you want better MPG, just keep it light and slow down. Or, buy an Airstream.
  • It would be interesting to see some studies of RV aerodynamics but as every RV is some sort of compromise, after a certain point improved aerodynamics will likely be at the expense of something else.
    My present 5th wheel has very good aerodynamics for a 5er but the trade off is reduced bedroom closet space and basement size.
    I'm thinking that contouring the 8' X 8" rear end enough to make a real difference in aerodynamics could make an RV quite a bit longer with a decrease in functionality. When it comes to efficient use of space, nothing is more functional than a box.
  • Mmmm...
    A flat rear wall affords things like windows, spare tires, ladders...etc.
    Maybe a contoured rear end just isn't thought to be that important.
    The soft round corner back end capped units do have a stylish pleasant look however.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
