lpranger467 wrote:
Thanks for all the replies. We have a seasonal site that we have reserved. It has sewer and electric. My plans would be to use bottled water only and to flush the toilet using a antifreeze/water mix and not turn on the water at all.
I'd like to get a 100 lbs propane tank, but if I have to switch 20 lbs bottles every 2 days or so it wouldnt be the end of the world for me.
I would like the option of using space heaters set on low maybe (750 watts) to supplement the heat so the furnace doesnt run as often.
We really have no choice but to be local due to our jobs, we have tried many different angles to rent a house/mobile home with absolutely no luck as all.
I'm frustrated to say the least but our cats are like our kids and we have to keep them with us for this move.
Your winters are going to be more harsh than where I live in PA and I would never consider attempting to live in a RV during winter. Your plan is fraught with issues and discomfort all to be able to keep your cats.
Even using RV antifreeze to flush your toilet isn't going to fully prevent issues with your black water tank and it will be expensive to do so at $3-$5 per gallon.
Your going to burn that 100lb propane tank easily in a week or less and still will feel cold/chilled. Adding in electric heaters will help to some extent but unless you have 50A hookups and site is not on a electric meter you are very limited to one 1500W heater max with 30A 120V service and if metered that will be the most expensive heat you will ever encounter.
Have a neighbor that used a small TT for one winter while their log home was being built.. They said that was the absolute worst idea and wouldn't want to do that again. They were always cold, used lots of propane and electric and still wore heavy coats inside the RV.
Find an pet friendly apartment or home you can rent over the winter, they do exist. May not be in the most ideal neighborhood or location to work but they are out there.
Barring finding a pet friendly apartment or home to rent, consider adopting out your cats to new good homes where they will be loved dearly.
Once your new home is built, then build your new family, heck you might even adopt some unloved cats that live in shelters and give those less fortunate cats a new permanent good home.
