dpgllg wrote:
You need to do a little more than just "drain" the plumbing.
Either use the Pink RV Antifreeze and run it through every line including toilet valve. Or use a compressor and really blow out all the lines. I was always a little excessive compulsive and did both.
I now store mine underground in a closed limestone mine about 2 hours away. Constant 54 degrees so no freezing. I still blow out the lines though. Cost is based on length and my monthly cost is less than $40 a month.
Dave
Yeah, I searched around Denver and no former mines used for storage and no county fairgrounds, which are the two cheap covered options around me. I'm surprised at that, looks like a business opportunity.
