DutchmenSport
Oct 26, 2019Explorer
Make sure all faucets are off. Make sure the water pump is off. Put the hose in the container with the pink stuff. Now, turn on the pump. It will run and run and run, and probably pump nothing. Keep the pump running, and NOW turn on a faucet. You will hear a different sound the pump makes and it will begin pumping the pink from the container. If the pink stuff runs empty, or switching gallons, repeat. Every faucet off. Water pump off. Insert hose in pink stuff container. Turn on pump, turn on one faucet at a time. If the jug runs empty, repeat again until all lines are running pink stuff.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
