dieseltruckdriv
Oct 28, 2019Explorer II
Bumpyroad wrote:Kansas couple wrote:
Yes, did the water heater bypass and flushed the pink stuff through the toilet.
This was not my first time winterizing the camper. Rather it was the first time I used the pump kit. Previous years I put the antifreeze into the fresh water tank. Not complicated but it sure uses much more antifreeze than the 2 or so gallons I used this time!
so you previously got antifreeze thru OK from the FW Tank but couldn't from the bottle/kit? and you did everything else the same? you did put the "T" valve before pump? doesn't compute??????
bumpy
Actually it does compute if there is an air leak. These pumps can run for days (yes I did it, oops) with no water but they don't like air leaks.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
