  • I am hoping to be able to camp till the end of October. Otherwise I will winterize when I have to.
  • I hate to see the posts start about winterizing, it seems like camping season just started.I guess it is coming for us all here in the north soon,I am not looking forward to it.
  • grizz272 wrote:
    Shoot, you still have 5 more weeks of camping left. I hope.
    LOL nope we blew out a tire so its replace tires in spring and an early nap for my baby. We had her out 7 to 8 times and had one hell of a summer!!!!
  • Campinfan wrote:
    Zell66--yes, you are spot on. Make sure you turn your pump on and turn the red lever to bypass for the water heater. I take out the anode on the bottom and open the pressure relief vavle on the top to help it drain. You do not need to add anti-freeze to the water heater.
    Thank you for the information.
  • Zell66--yes, you are spot on. Make sure you turn your pump on and turn the red lever to bypass for the water heater. I take out the anode on the bottom and open the pressure relief vavle on the top to help it drain. You do not need to add anti-freeze to the water heater.
  • So i use the hose just under the city water supply to draw up the antifreeze and the valve is for that hose?
  • I have the same trailer. It is used to draw the antifreeze out of the hose that goes into the bottle instead of drawing from the fresh water holding tank. I had to figure it our the hard way.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
