RobWNY's avatar
RobWNY
Winterizing Fresh Water Drain
I've searched on this site and googled but I can't find any information specific to this issue. I have my 5th wheel all winterized including the low point drains and valves. I drained out all of the fresh water and closed the drain. The next day, I opened that drain and maybe a couple ounces of water came out. The same thing the following day. I'm assuming there is drops of water in the line finding its way to the valve but how many times should this happen? Is there a way to winterize that valve without getting anti-freeze in the fresh water tank or do I leave the valve open all winter? If I do that, how do I prevent spiders etc. from finding their way into the tank? Thanks!
  • Air is the answer. Buy an adapter and put it on your fresh water intake connection then have a pressure tank set to about 40 psi and blow out everything.
    Having said that, I always leave my drains cracked open, but if you are worried, put a cloth over the tips of the drain hoses and a rubber band over that to hold it on.
  • I've thought about you question and the only way I can see to winterize the drains is to put anti freeze into the tank or the lines to the sinks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
