wbwood's avatar
wbwood
Winterizing Survey
There was a discussion in the Class C area about winterizing and my post had me go look in the manual of my new Class C as I had not done yet, to see their recommendations for winterizing. One of the comments on there had me wondering. It mentioned draining the black tank and gray tank. I never drained them completely in my TT. Nearly empty, but just some still in there. I did make sure there was plenty of pink stuff in them too. But if you drain the black tank completely, will you run the risk of odors? I would still put some pink stuff in, but wondering about what possibly could still linger in the tank.
So with avoidance of whether you blow the lines or do it the wet method of pumping it through the lines from the water tank, do you drain the black tank completely? Or do you leave a little water in there as well?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
