Gdetrailer
Apr 30, 2021Explorer III
Have another idea, thinking outside the box..
Found HERE for $58
That is a 1000W belly band drum heater, designed to wrap around the outside if a drum to heat oils and fluids in winter. Includes adjustable T-stat. With some creative thought you could either wrap around part of the stove then create a "cover" to hide it or might be able to attach to the inside of the stove via high temperature silicone caulking (silicone will transfer heat from the band to the metal).
Add in flicker lights for "ambience"
The also make 1200W versions.
As someone also mentioned, it will take a long time to heat cast iron..
Found HERE for $58
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
