Olddawgsrule's avatar
Olddawgsrule
Working from the road
Hoping this is the right place to post this..
I will be working from the road for a couple days a week and will have to plan my stays accordingly and internet service.
To anyone that relies on internet, How do you fair?
My assumption is the campgrounds with WIFI are probably slow, possibly too slow for my needs. But, I don't know..
Hey, that's why your here! So I can ask and learn.
  • Thanks folks! Man you folks are active!!
    I will have files in the 400mb range (normal size) but do have 2gb at times. I've not even tried D/L'ing anything that large through my phone before..
    Well, first time for everything, right?
    How's At&T in Canada? I have Verizon and works well (Quebec and East anyway).
  • we also work on the road and use AT T go phones for our hot spot. we each have 8 gigs and that is more that enough for what we do
    we also need the hot spot because it is a secure connection.
    most campground wifis are not all that good or reliable.
    we also hve a wilson electronics cell booster that helps boost our signal
  • not only are campground wi-fi systems not reliable they are not secure. We use Verizon Mi-Fi Jetpack. Works well all over the US. Be careful with what plan you use. Their new "unlimited" plan throttles the speed. I switched to their "unlimited" plan and switched back because it was too slow. Also not cheap.
  • Along with everyone else we rely on a "mobile hotspot", and use ATT there has been only one location where we had that area no service and that was Hillsville Va. Verizon has that area sown up. Had to go down the interstate to get service. Good Luck and Happy Camping !!
  • We were on the road for 6 months through 16 states in the southeast. We had Verizon 4g service on the hotspot in all but one campground (Withrow Springs SP in NW Arkansas). Verizon now offers unlimited data for around $100 a month.
  • x2 on the hotspot. But consider that if you are in an area with no or weak cell service, you'll be no better off than if you have campground wifi. Something else to consider. When you pick a spot to stay, ask the campground if a particular provider (ATT, Verizon, whatever you use) service works there. Don't count on the provider maps to be reliable. I stayed in an RV park that showed very strong 4g LTE on the map, but did not work at all in the park due to the surrounding terrain.
  • Your assumptions are generally correct IMHO. We use our own AT&T Hotspot for Internet access and it works fine in most places.
