Cummins12V98 wrote:
Sorry but rating are ratings! It's all about who can do what and the bigger the better claim is going to get the most attention.
If your truck sits level when loaded or a bit higher in the rear when loaded you are fine. But soft tires are dangerous when you start to sway, I know from experience. Rolled over!
Use my words of experience if you want but quality shocks and a firmer tire may save you from a bad experience.
Start with the Bilstein's, you will likely do fine with the 4600's. Yes, not cheap, but if bounce is the issue, the Bil's will take care of it.
The better tires can come later.
