InTheRockies's avatar
InTheRockies
Yellowstone Next Week - Freezing Temps Concern
I’ll be in Yellowstone next week in my TT and am concerned about temps dipping below freezing at night. My holding tanks are all exposed below the underbelly. I can easily run some RV antifreeze through my supply lines via the water pump and use water containers for my fresh water needs, but am not sure about the waste tanks. I won’t be able to avoid using the gray and black tanks. I can pour antifreeze in the drain lines but it will be diluted by the gray and black waste water. Is the answer just more antifreeze? Any temporary and easy insulation I can rig up for the exposed tanks and low point drains?
Forecasted low temps look to be around 30-35. Am I worrying too much?
Thanks in advance.
    Yes. Most any RV is fine down to 25 while in use.
  • According to my FIL who was a manager for the Dept Of Agriculture, rapid freezing occurs at 26 deg F. And that means in an hour or two for a water hose. But up in the thirties it is not an issue if the temps are above freezing during the day, most of the time. We had a water hose freeze a few weeks ago outside Bryce, was not watching the weather closely. No big problem, thawed out in a couple hours, no damage.
  • I've spent many days below freezing in my trailer. Sounds like I have a bit more insulation than you have, but I wouldn't worry. The heat from the trailer will keep you from freezing. One piece of advice - have at least half a tank of water in your fresh tank. I have been there when the water spigot froze, and I didn't have enough water in my fresh tank to last the day.
  • A couple weeks ago we experienced several nights below freezing in our travel trailer in Arizona and Utah. The coldest night was 24 degrees. Had absolutely no problems. The only thing I did to prevent problems was to remove the outside shower head from its hose and bring it inside. The valves for the outside shower were still vulnerable, but there wasn't much I could do for them other than keep the bathroom cabinet door open and the bathroom door open to allow warmer air to access the areas closest to the outside shower.
    Temps around 30? Nothing to worry about.
    -Speak
  • Thanks for all the input. I’ll take the advice here and not worry about temps in the low 30s.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Another factor people forget
    32 degrees F or 0 C is the freezing point of DISTILLED water at precisely one atmosphere pressure.. Different pressure will change the freezing (and boiling) points.
    Impurities will also LOWER the freezing point (And generally raise the boiling point) That water in the black and gray tanks... VERY VERY Impure.
  • PatJ's avatar
    PatJ
    Explorer II
    I was worried my first few cold nights in my "new" (2019) rig as I do not have tank heaters or anything fancy like that. I have since spent many nights below 30 and two nights where I woke up to 20f and no issues so far. So far I have pictures in 5 states with snow all around my rig. I didn't try to flush tanks at 20f, but nothing broke dropping down there for a few hours late night/early morning and we used the rig normally. My drain/flush valves are what I was most concerned about.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
