I_Fish_2
Sep 25, 2014Explorer
Thanks Old Biscuit. I'm thinking along your lines. I'm tempted to start replacing the spade connectors. I'm thinking one of them might not be getting good contact, and when I had them off and on the other day, it "fixed" itself temporarily. I already checked the grounds. They look ok, except there is no ground under the circuit board.
As to the thermal fuse, he said that the pop off valve seeps water that drips into the fuse, causing calcium build up and corrosion. That in turn causes a sporadic connection, and the constant fluctuation in voltage, in time, does the circuit board in. He said remove it per Atwood's instructions.
