xyzHollyxyz's avatar
xyzHollyxyz
? 2015 Dometic 2-Door Fridge (2652 or 2662?)
I left yesterday on my Big Adventure 2016. Fridge has been working fine on both electric and propane while sitting in its garage.
When I unplugged yesterday morning to leave, I waited for the fridge to go to propane automatically. It did.(temps were low 30s and 5) Propane tank is a 20 lb'er and newly filled. Burners on stove light, so I have propane.
When I pulled in for the night (520 miles), the wireless temperature sensors read 45 and 20! Weird.
So, I plugged the trailer in to electric at the campground, but forced the fridge to stay on propane.
When I got up this morning, fridge was 35 and freezer was 6.
I just now stopped for night 2 and the fridge is 45 and the freezer is again 20.
The fins in the back of the fridge compartment are full of moisture, as if they defrosted.
Do you know of anything I could check or why this might be happening - that the fridge worked fine last night overnight while on propane, but not while traveling today? **** fridge is just a year old and has barely been used!!
Thanks!
  • xyzHollyxyz wrote:
    Just a warm box - no CHECK light.
    Yes, on 12v source - brand new, fully charged Group 31 battery.
    Yeah, but do you have a properly operating charge line to maintain that battery as the fridge is drawing it down as you drive? :@
  • Check Dometic web site first of all for recalls, then, see if they have a kit to prevent blow outs. Otherwise a piece of sheet metal stregicatly placed should do the trick.
  • OP here. I have unplugged from shore power and the fan is still running and it appears the temp is dropping.
    If it's blowing out while I drive, how do I prevent that?
  • Just a warm box - no CHECK light.
  • Burner is not lighting. Do you have a good 12VDC source? It may be blowing out while going down the road. Do you get a fault light or simply warm box?
