dougrainer
Oct 02, 2014Nomad
The FIRST thing that needs to be done is verify that you do INDEED have TRUE 50 amp service. Take a voltmeter and check the voltage between the 2 hot leads at the CG 50 amp plug. It should be 220/240 or double the line voltage. IF it does not read double, then you are NOT on 50 amp service(100 AMPS TOTAL) but on a single phase 50 amp breaker. This would be the cause of your PI dropping out. Also a loose NEUTRAL at the CG power receptacle may also cause voltage problems with full 50 amp service. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
