kabbro
Aug 20, 2021Explorer
Update: went to the storage building. First thing was to test voltage with a voltmeter (negative terminal on battery is always disconnected in storage)...starting voltage was 12.56 volts...connected battery and went in to check out converter...had 3 lights on and slide in-and-out...there was not a decrease in lighting during the 48 minutes I was in-and-out...tested voltage at the end and it was 12.30, took battery home and is now charging.
Re: converter...factory check-list at buildout identifies converter manufacturer as CHENG...trailer is Model Year 2009. 99% sure this is original converter (I purchased trailer used)...apparent Model Number is 351-ED49001. YJ 0808 E237684-SBI-4-2
Also, looking at the whole panel including the circuit breakers and apparently converter there is a listing of WF8955 PEC.
Googling all of these numbers doesn’t seem to result in an exact match of numbers but seems to get one into WFCO or converters avail on Amazon and other sites.
Appreciate any thoughts or insights or suggestions. Thanks
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
