enblethen
Aug 27, 2021Nomad
Converter output seems to be working. Now test at 12 volt DC battery connection, then go immediately to the battery and check voltage on battery. Readings should be nearly the same allowing for slight voltage drop. Maybe .1-.2 volts
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
