xyzHollyxyz
Jul 31, 2016Explorer
Darryl&Rita wrote:
Door frame is surrounded by weather-stripping. Run it between the door and the frame, then you won't have the wind whistle from the window part-way open.
That door will be opened and closed a lot on this trip. I was thinking that perhaps not subjecting the antenna wire to that constant slamming would be better for the wire by going through the window, which will not be opened and closed?
Or are you saying that the rubber weather stripping will kind of provide a protective "give" during opening and closing the door?
