Muddydogs
Jul 31, 2016Explorer
Chances are your inside dome light above the rear window and brake light on the cab are separated by a cardboard material. Run the cable into the bottom of the brake lense, poke a hole in the liner, run the cable out the bottom of the dome light, use the rubber seal around the rear window to hide the cable, once the cable is on the floor run it under the carpet or door jam to the front of the truck. My ham radio body sets on the hump in front of the front seat so I just got my cable to the front seat then ran it under the seats.
When I go to sell the truck everything comes off and unless they pull the brake light or dome light no one will be the wiser.
