opnspaces
Mar 27, 2020Navigator III
That's a big it depends.
If you are talking about changing taillights on a trailer and leaving the tow vehicle alone then yes they should work fine. The stock tow vehicle lights already provide enough resistance to flash. Or if they are LED the required flasher is already installed.
If you are talking about a class A B or C which has normal incandescent lights; You will have probably have to add a new flasher unit in addition to the new LED taillights.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
