valhalla360
Mar 28, 2020Navigator
opnspaces wrote:valhalla360 wrote:
For brake lights in particular, there is one huge advantage going to LED.
Incandescent bulbs light up approximately 0.5 sec after power is applied.
LED light up approximately 0.05 sec after power is applied.
That means the driver behind you gets an extra 0.45 sec to react. May not sound like a lot but even if they still hit you, it will be at a slower speed and therefore should be less serious.
True it's a bit off topic, but you can break it down even further.
At 60mph your car is traveling 88 feet per second. 5260/60=88
At 88 feet per second you are traveling 8.8 feet every tenth of a second. 88/10=8.8ft
Now take the numbers from valhalla360. Even rounding the .45 down to .40 you will travel 35.2 feet in 4 tents of a second. 8.8*.4=35.2 That's more than the length of a standard traffic intersection. So the LED coming on .40 seconds faster than the incandescent will give you an additional 35.2 feet of stopping distance.
It's a little more complicated as both vehicles are moving (your explanation presumes the braking vehicle light comes on after it's at a full stop).
But if in the original situation, you brake a little too late and would hit at 10mph, moderate braking (10mph/s) for (let's round it to 0.5sec for easy math), would result in a 5mph hit. Run the formula for momentum and that's a lot less impact. In a panic brake (20mph/s), you will come screeching to a halt and maybe barely tap the bumper of the lead vehicle.
No it won't help if the following driver never brakes but how many times in a traffic jam, do you slam on the brakes and barely miss hitting the guy in front of you (or you fail)...an extra few tenths of a second will eliminate a lot of those failures.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
