- BumpyroadExplorer
rrupert wrote:
I have seen a number of times that the bulbs should be replaced with red LED bulbs because they show up better.
the original bulbs should be adequate, but if you want to throw money away, have at it. I think I have replaced a dozen at most old style bulbs over the years.
bumpy - Cummins12V98Explorer IIIThis is what I replaced the incandescent units with. I could have simply replaced the lamps with LED's but this was FAR BETTER!
- mich800Explorer
bumpy
Actually the school of thought I have read is to use the same color bulb as the lens to maximize color and brightness. Below is per Super Bright's website.
which color to use - BumpyroadExplorerI somebody is that anal about their tail light brightness, I would suggest getting a set of magnetic lights and put them on the trunk of their car and plug into the 4 flat connector.
bumpy - mich800Explorer
bumpy
They are the same price. Why would you be opposed to purchasing the proper bulb for the location and fixture? - theoldwizard1Explorer II
Busdriver wrote:
If you have regular tail, stop, turm taillights, can they be changed over to plug & play lights
Not on all vehicles !
Some very new vehicles will "sense" that there is a very low "load" and then report that you have a burned out light bulb ! - theoldwizard1Explorer II
fj12ryder wrote:
The turn signals bulbs are usually the only problem since they flash really quickly with a normal flasher. They have specific flashers or you can add in a resister, or they may come with resisters built-in.
Adding the resistor completely defeats the primary reason for switching to LED taillights, reduction in power. - theoldwizard1Explorer II
bumpy
22 yo vehicle. I have replaced ONE bulb. - valhalla360NavigatorFor brake lights in particular, there is one huge advantage going to LED.
Incandescent bulbs light up approximately 0.5 sec after power is applied.
LED light up approximately 0.05 sec after power is applied.
That means the driver behind you gets an extra 0.45 sec to react. May not sound like a lot but even if they still hit you, it will be at a slower speed and therefore should be less serious. - fj12ryderExplorer III
theoldwizard1 wrote:
Hey, I didn't make up the laws of physics. That's just the way it works, really doesn't matter that you don't like it.fj12ryder wrote:
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
