- BumpyroadExplorerthe last time I was rear ended, it was due to total negligence of the other driver. that excuse of a brake light coming on quicker, sounds to me more like a reason to convince the wife that, "yes dear, it makes sense to spend $14.99 for a perfectly good bulb whereas the current 99 cent one is perfectly adequate.
the requirement for an eye level brake light is more meaningful than a millisecond faster reaction.
bumpy - opnspacesNavigator III
valhalla360 wrote:
For brake lights in particular, there is one huge advantage going to LED.
Incandescent bulbs light up approximately 0.5 sec after power is applied.
LED light up approximately 0.05 sec after power is applied.
That means the driver behind you gets an extra 0.45 sec to react. May not sound like a lot but even if they still hit you, it will be at a slower speed and therefore should be less serious.
True it's a bit off topic, but you can break it down even further.
At 60mph your car is traveling 88 feet per second. 5260/60=88
At 88 feet per second you are traveling 8.8 feet every tenth of a second. 88/10=8.8ft
Now take the numbers from valhalla360. Even rounding the .45 down to .40 you will travel 35.2 feet in 4 tents of a second. 8.8*.4=35.2 That's more than the length of a standard traffic intersection. So the LED coming on .40 seconds faster than the incandescent will give you an additional 35.2 feet of stopping distance. - fj12ryderExplorer III
MEXICOWANDERER wrote:
As I stated earlier:
Smarten up.
A Sure Power flasher cost me extra. Not only will it keep flashing into infinite resistance it will aurvive a dead short and even reversed polarity.
There is no reason to screw around with resistors
Plug and play except with newer nightmare H.A.L. controlled vehicles.
"They have specific flashers or you can add in a resister, or they may come with resisters built-in."
Guess I didn't spell it out clearly enough: Specific flashers that will work with LED's. - MEXICOWANDERERExplorerSmarten up.
Plug and play except with newer nightmare H.A.L. controlled vehicles. - fj12ryderExplorer III
theoldwizard1 wrote:
Hey, I didn't make up the laws of physics. That's just the way it works, really doesn't matter that you don't like it.fj12ryder wrote:
The turn signals bulbs are usually the only problem since they flash really quickly with a normal flasher. They have specific flashers or you can add in a resister, or they may come with resisters built-in.
Adding the resistor completely defeats the primary reason for switching to LED taillights, reduction in power. - valhalla360NavigatorFor brake lights in particular, there is one huge advantage going to LED.
That means the driver behind you gets an extra 0.45 sec to react. May not sound like a lot but even if they still hit you, it will be at a slower speed and therefore should be less serious. - theoldwizard1Explorer II
Bumpyroad wrote:
rrupert wrote:
I have seen a number of times that the bulbs should be replaced with red LED bulbs because they show up better.
the original bulbs should be adequate, but if you want to throw money away, have at it. I think I have replaced a dozen at most old style bulbs over the years.
bumpy
22 yo vehicle. I have replaced ONE bulb. - theoldwizard1Explorer II
Adding the resistor completely defeats the primary reason for switching to LED taillights, reduction in power. - theoldwizard1Explorer II
Busdriver wrote:
If you have regular tail, stop, turm taillights, can they be changed over to plug & play lights
Not on all vehicles !
Some very new vehicles will "sense" that there is a very low "load" and then report that you have a burned out light bulb ! - mich800Explorer
Bumpyroad wrote:
I somebody is that anal about their tail light brightness, I would suggest getting a set of magnetic lights and put them on the trunk of their car and plug into the 4 flat connector.
bumpy
They are the same price. Why would you be opposed to purchasing the proper bulb for the location and fixture?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
