doxiemom11
Feb 17, 2020Explorer II
Using for furnace for heat maybe along with something else will help reduce moisture. For closets or small enclosed spaces, I use Damp Rid and change them out every month or so ( you can tell when they need to be changed). Running the air conditioner also removes moisture from the air. Sometimes when it's hanging at 65 and just a little too cool, I have used the heat for awhile, then turned the A/C on, cooled it down and repeated. After 3 or 4 times the humidity will be at an acceptable level.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
