Bumpyroad wrote:
TechWriter wrote:
Bumpyroad wrote:
thus previous discussions of having both an autoformer and a muti-function surge protector, and the debate which goes in line first.
TRC recommends their 44270 (open ground, open neutral, polarity tester) in front of their Voltage Regulator and a multi-function surge protector after it.
swell, now I gotta daisychain 3 devices. :)
bumpy
Actually, the 44270 is just an expensive fault indicator. It will NOT disconnect when it sees a fault. So after plugging it in and seeing no faults, I guess you could just disconnect it and connect the Voltage Regulator direct to pedestal.
