landyacht318
Nov 07, 2015Explorer
0.0 amps at 15.1v on an AGM
I've been using the 0.5% of capacity at 14.46v as an indicator as to when to stop charging my Northstar group 27 AGM.
But I have also let voltage to stay at 14.46 overnight, and the Ammeter reads 0.0 amps at 14.46v in the morning. Obviously some current is required to hold it at 14.46v but my tools cannot read it.
The other night after 4 deep cycles with a low and slow solar only recharge, voltage under load for the AH removed was not impressive, and I decided to let the Meanwell do its 40 amp thing until amps taper to 0.42amps at 14.7v.
When it got there I lowered voltage to 14.0v and let amps taper to 0.0a.
For grins I bumped voltage upto 15.1v, and it only took 0.1amps to get it there, and then it dropped back to 0.0amps quickly. I bumped it upto 15.5v, and the same thing. 0.1 amps tapered to 0.0 amps.
I guess there is little danger of popping the vents at these high voltages when the battery is already brimming full, and needs so little current to be held at these voltages.
The next discharge, the performance( judged by voltage held for AH removed under a certain load) was back. I love a battery which loves high amp recharging, I just wish it was also happy with the 200 watts of low and slow solar taking all day to get to 0.42amps at 14.46v.
But it is so Obviously unhappy with the low and slow recharge treatment. I watch performance drop every night until it gets its high amp recharge.
It really seems the higher the amp are, applied from its most depleted State, the happier this battery is.
I think I am going to add my Schumacher's ~29 amps to my Meanwell's 40 the next time I blast it from 50%. The Schumacher should not drop out for a while. It depends on if it is in its 16.4v masochistic mode or not
