msta999's avatar
msta999
0020102 generac 4800 choke problem/water heater
Last fall, when starting the generator, it had to crank a long time to start, so I performed a tune up, changed the oil and filter, air filter and fuel filter, when to start it and no change, looking at it I noticed the choke is not closing when cranking, if I manually close it it starts right a way, anyone use this type of generator? Ran across this problem before? I hope to dig into it more this weekend.
Also, I didn't drain the hot water tank a two years ago and it burst, know where I can get a replacement?
This is in a 24ft Carson Toy Hauler
  • I noticed the connector with the two red wires, coming off the choke solenoid only has one red wire, i cant find the other one, i see the terminal in the connector......looks like the wire broke off it. If any of you can see yous, can you tell me where the small red wire goes?
  • Old-Biscuit wrote:
    Atwood G6A-7 Replacement Unit
    Atwood 96202
    Atwood G6A-7 model replacement tank
    Atwood 91412
    Good luck finding EITHER
    Dometic acquired Atwood several years ago and has stopped production/support for the 6 gal models
    They have a new 6 gal Dometic Model --- it is NOT a direct replacement for the Atwood 6 gal (Taller, narrower)
    Be easier to replace your 6 gal with a Suburban
    I have been looking, but like you said, they are hard to find! Looks like i may have found s replacement tank, but i have to call themp
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
