josslund's avatar
josslund
'02 Adventurer Basement air
I'm out in the RV and my basement air/heat pump won't come on. Checked all the fuses and circuit breakers on the coach. Is there one on the unit itself? fan comes on. thermostat does not seem to be working, as nothing is showing on the LED for temp. Any thoughts from the community?
  • I have a 02 Adventure, and you are going to have to get
    power to the thermostat FIRST. I have had no trouble
    with my basement air, cept early on the thermostat would
    not pick up the second compressor sometime. tenn.......
  • If you'll post the model number for both the heatpump and thermostat the guys can give you accurate troubleshooting help. Otherwise it's just guessing.
    I'd guess, if your thermostat is digital then it has a battery that needs replacing. You need power to the thermostat to close the relays.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
