Old-Biscuit
Apr 24, 2017Explorer III
To properly clean the 'burner tube'....yes remove and use a small bottle brush to clean it
While you have it out...unscrew orifice on gas valve. Soak in alcohol and then blow dry. Just blow on it....high air pressure from air compressor can damage it
BBQ lighter at END of burner tube
Putting a flame need the 'air inlet' to check propane flow......NOT unless you want to have a 'puff' .
But it probably wouldn't light anyway due to improper air/fuel ratio....
Try a BBQ Lighter at END of burner tube
