path1's avatar
path1
10 gal suburban DSI water heater won't start
Last time used may 2016. Furnace works, stove works (so I do have propane)
When I turn on switch from inside RV I can hear the spark thing making clicking noise but it doesn't fire off. Clicking stops and then tries again and again. I'm thinking spider webs or such.
Any hints to a good tool to clean out the brass air tube looking thing without taking it off?
I can not smell propane when its trying to start. Is it OK to put a match to the little orifice to see if propane is it thru the orifice? Or is there maybe to much volume of propane and don't put a match to it.
Any other ideas?
Thanks
(Added on to orginal post)
Tried again and I can now here the clunk verses the spark thing. Is noise from some type of valve or solenoid?
  • donn0128 wrote:
    Did you purge the gas lines prior to attempting to light the WH? Did you leave the propane tanks on?
    NO, did not purge. But stove line is probably within 3 feet of water heater. Yes, propane tanks have been on since cold snap in January.
    Also added info post.
  • Did you purge the gas lines prior to attempting to light the WH? Did you leave the propane tanks on?
