pianotuna wrote:
StirCrazy wrote:
LFP are not subject to thermal runaway like nicad and other chemistries.
It is only more difficult. It can, and does happen.
https://onlinelibrary.wiley.com/doi/abs/10.1002/er.5298While it is unusual here is what may happen.
https://youtu.be/07BS6QY3wI8
All battery banks should be vented to the outside.
IMO, it's important to put both of these links into context.
I believe the wiley.com link references a minor amount of thermal runaway (caused by overcharging) where damage is completely limited to the inside of the battery. The user may see the top "vent" rupture, but nothing more. I would surmise if a typical
non-phosphate, lithium battery was subjected to the same overcharging, it would very likely explode and/or erupt in flames. Huge difference IMO.
I've seen this YT video before. To me this is akin to someone purposely puncturing a gas tank on a vehicle and having it explode or catch fire. It can happen, but . . .
Will Prowse at diysolarforum.com was the OP for a thread titled:
"Can LiFePO4 Batteries Combust in Thermal Runaway Event?" One of his comments after someone posted a link to the above YT video: "
The electrolyte is flammable. If a cell is physically damaged, you can catch it on fire. But for an exothermic reaction to occur to cause combustion, from the literature I've read, is impossible with lifepo4 . . . to have combustion caused internally, is impossible."Lastly, I'm not aware of any external venting requirements for lifepo4. Do you have any supporting links that explain why this would be necessary? Thx.
