pianotuna
Jul 15, 2021Nomad III
BFL13 wrote:
I like my Tracer MPPT and also liked my EPSolar PWM in a previous set-up.
I see the newer panels have 12 busbars for higher efficiency, eg
http://www.wegosolar.com/products.php?product=QCELL-350-Q.PEAK-DUO-BLK%252dG6%252b-350-Watt-Solar-Panel-BLK%7B47%7DBLK%7B47%7DBLK
Hi BFL13,
I'm looking at these poly cells as they are shade tolerant.
https://microgreen.ca/downloads/solar-panel-360w-REC-datasheet.pdf Cost is $300 for a 360 watt panel.
They are smaller, lighter, and produce more watts than the Q-cells.
If I buy four I am hoping I won't need a rack on the roof. I'll go flat fixed again.
I'll also go series parallel again to boost the possible charging times, while reducing wire size.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
