MEXICOWANDERER
Apr 12, 2015Explorer
EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Ain't tinnitus fun?
I did a considerable amount of R&D for "Northwest Regularor" back in the early 90"s. I learned just how nuts stereo competition got 24-years ago. Some of the rigs had new-on-the-market Lifelines. Like six of them in the trunk. My job was to develop fittable alternators with custom wound rotors and stators. At the time I worked with the smaller frame 3-G Ford and managed to improve amperage at 1,600 rotor RPM by 32-amps and total hot amperage to 142. For small Nissans, and Hondas. Couldn't stuff a larger frame alt in there with a jackhammer and shoehorn.
The ND hairpin 270-ampere alternator would be my favorite today. But not with it's original voltage regulator. Absolutely those regs for the 200-ampere and 270-ampere hairpins are junk. The control voltage settings are ALL wrong for absorbed glass mat. Especially when subjecting the batteries to long periods of charging. Driving.
I would gut the OEM regulator and fit a B Circuit regulator. AMPLE POWER makes a programmable alternator voltage regulator that has a field driver NPN mosfet that can endure thehigh field currents of the Hairpin alternators. The AMPLE POWER regs have thermistor temperature compensation. I know David Snead the owner of Ample Power and he knows his stuff. A 270-amp Hairpin coupled to an Ample Power regulator is a setup that stays with the owner and not the rig. The hairpins have big bearings and long brushes - which I like. But I much prefer the 270 over the 200 for low rotor speed work. The reg can be adjusted for flooded, lithium or AGM voltage curves.
Hope this helps
Ain't tinnitus fun?
Hope this helps
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
