BFL13
Apr 12, 2015Explorer II
Yes, the knob should be marked around it for a few favourite voltages like 13.6 and 14.8 when it is not connected to a battery (bench test situation) so you can dial that in when on battery. The battery skews the voltage showing on the charger's voltmeter otherwise.
I don't worry much about precision since it is all over the map due to temperature anyway. I use my 14.8 marker then add a bit if it is cold out. Close enough for government work! :)
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
