MEXICOWANDERER's avatar
Aug 15, 2015
100% Of The Capacitors Turn-Around In My Old WhiffCo.
This is a question not a statement. I am seeking clarification about the designation of THE LONGEST LASTING capacitors for my old 55-amp WhiffCo. 3, actually 1 stage converter.
First of all I WANT IT TO BE FIXED VOLTAGE. 13.6 for my use is fine.
But true to form when my laptop blew up it took information with it about replacing capacitors with PANASONIC ESD capacitors.
In my new-to-me 5-lb NEWARK catalog I found a category for "Low ESD Panasonic capacitors rated at 10,000 hours at 105 c operation" Are these the longest lasting I can use or is there an even "better" grade?
With the Mega's in the charger I have an alternate. I won't need higher voltage from the WhiffCo. Instead I will isolate the output with yet another monster Schottky rectifier set and drop voltage from 13.6 to 13.3, and with DO-5 silicon rectifiers voltage can drop to the high thirteens. But a repeat of the diagram for the unit showing which resistor to replace (I'll do it with pot) would be a constant temptation.
Caps fail over time. Holes get punched electronically in the wraps. I am considering a full-on capacitor replacement - every last one in the unit. Is there anything else that could be upgraded? I can purchase upgrade transistors for instance. A ziploc emergency repair kit. I'll do an audit of the components and make sure I have enough spares. Where I haunt, a "resistor" is placed in handcuffs.
This time answers get copied to Microsoft word then stored on USB flash memory.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 10, 2026
